Calculate Actual Current Shrinkage and Budgeted Shrink to Apply to Stock Ledger (stkdly)
Module Name |
stkdly.pc |
Description |
Calculate Actual Current Shrinkage and Budgeted Shrink to Apply to Stock Ledger |
Functional Area |
Stock Counts |
Module Type |
Business Processing |
Module Technology |
ProC |
Catalog ID |
RMS359 |
Wrapper Script |
rmswrap_multi.ksh |
Design Overview
The Stock Count Shrinkage Update batch calculates the 'value' variances for Unit & Value stock counts. The main functions are to calculate actual shrinkage amount that is used to correct the book stock value on the stock ledger and to calculate a budgeted shrinkage rate that will be applicable until the next count. Additionally, future transaction data snapshots are aggregated and stored into a table which will be used for shrinkage calculations in month end stock ledger batch process. The month end stock ledger batch process then uses these values when calculating ending inventory for the month.
