Close Overdue Transfers (tsfclose)
Module Name |
tsfclose.pc |
Description |
Close Overdue Transfers |
Functional Area |
Transfers, Allocations and RTVs |
Module Type |
Admin |
Module Technology |
ProC |
Catalog ID |
RMS379 |
Wrapper Script |
rmswrap_multi.ksh |
Design Overview
This batch program processes unshipped and partially shipped transfers that are considered 'overdue', based on system parameter settings. If this functionality is enabled, then this program will evaluate transfers to determine if they are overdue. The way that a transfer is considered overdue depends on the source and destination locations. There are separate system parameters for each of store to store, store to warehouse, warehouse to store, and warehouse to warehouse types of transfers.
For unshipped transfers, the transfer status is updated to delete and transfer reserved and expected inventory is backed out from the table for the sending and receiving locations respectively. For transfers that are shipped but not fully received, an entry is made into the document close queue table. These transfers are picked up by docclose batch and closed after reconciliation.
