Create Return to Vendor for Mass Return Transfer (mrtrtv)
Module Name |
mrtrtv.pc |
Description |
Create Return To Vendor for Mass Return Transfer |
Functional Area |
Transfers, Allocations and RTVs |
Module Type |
Business Processing |
Module Technology |
ProC |
Catalog ID |
RMS275 |
Wrapper Script |
rmswrap_multi.ksh |
Design Overview
This batch program creates RTVs for approved mass return transfers that require an RTV to be created automatically and have an RTV create date earlier than or equal to the current date. RTVs are created in either Input or Approved status, depending on how the MRT was created. The program will then set the status of all processed MRTs to ‘R' in the MRT table, which indicates that the RTVs have been created.
