Load Spreadsheet Templates (ld_iindfiles.ksh and loadods.ksh)
Module Name |
ld_iindfiles.ksh, loadods.ksh |
Description |
Load Spreadsheet Templates |
Functional Area |
Item Maintenance |
Module Type |
Install |
Module Technology |
ksh |
Catalog ID |
RMS199 |
Wrapper Script |
N/A |
Design Overview
These scripts are used to load data from template files to the Merchandising template tables as part of installation. They load templates used by induction processes for Merchandising and Pricing, as well as templates used for spreadsheet load of foundation data. They may also be run ad hoc in situations where the base files need to be reset.
There is no wrapper script for these programs. They are invoked directly by the installer.
