Process Stock Count Results (stockcountprocess.ksh)
Module Name |
stockcountprocess.ksh |
Description |
Process Stock Count Results |
Functional Area |
Stock Counts |
Module Type |
Business Processing |
Module Technology |
ksh |
Integration Catalog ID |
RMS366 |
Wrapper Script |
rmswrap_shell.ksh |
Design Overview
The Stock Count Process batch processes actual count data from the selected store or physical warehouse to count/item/location table from the data staged by STOCKCOUNTUPLOAD.KSH. For a physical warehouse, this process also calls the Merchandising distribution library to apportion quantities to the virtual warehouses in Merchandising.
Restart/Recovery
The logical unit of work for stockcountprocess.ksh is a set of a single or multiple valid items at a given location. This set is defined as a chunk. Based on the example above, if for some reason, chunk 2 raised an error, INPUT FILE 6, 7, and 8 wouldn't be processed by this program. Other chunks, if there are no errors, would be processed. User has to correct the transaction details and upload the input file again that includes the affected CHUNKS for reprocessing.
