Purge Aged Cost Component Exceptions (elcexcprg)
Module Name |
ELCEXCPRG.PC |
Description |
Purge Aged Cost Component Exceptions |
Functional Area |
Costing |
Module Type |
Admin |
Module Technology |
ProC |
Catalog ID |
RM S222 |
Wrapper Script |
rmswrap.ksh |
Design Overview
In Merchandising, you are allowed to make rate changes to cost components, up-charges and expense profiles with future effective dates. Additionally, when these future rate changes are specified, you can choose to cascade these changes to lower levels. The options for how the updates can be cascaded are described in the table below:
Table 3-3 ELCEXCPRG.PC - Cascade Options
| Updated Entity | Cascade Options |
Expense Profiles (Country, Supplier, or Partner) |
Order, Item |
Cost Component (Expense) |
Country, Supplier, Partner, Item, Order |
Cost Component (Assessment) |
Item, Order |
Cost Component (Up-charge) |
Department, Item, Transfer/Allocation |
Department Level Up-Charges |
When the processes that apply these changes run, they may raise exceptions if the rate for an entity has been overwritten prior to the application of the future rate change. If so, then exceptions are written to the COST_COMP_EXC_LOG table. This program purges the records from this table based on a number of retention months that is passed as a runtime parameter.
