Purge Aged Stock Count (stock_count_purge_job)
Module Name |
stock_count_purge_job |
Description |
Purge Stock Count |
Functional Area |
Stock Counts |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two-step processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from stock count header table based on its purge criteria from system variable settings. The Last End-of-Month Start Month parameter will determine records with earlier stock take date or those that have been flagged for deletion. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from stock count related tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 16-2 Key Tables Affected
| Table | Select | Insert | Update | Delete |
SYSTEM_VARIABLES |
Yes |
No |
No |
No |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
B8D_STOCK_COUNT_PURGE_STG |
Yes |
Yes |
No |
Yes |
STAKE_LOCATION |
Yes |
No |
No |
Yes |
STAKE_QTY |
No |
No |
No |
Yes |
STAKE_CONT |
No |
No |
No |
Yes |
STAKE_SKU_LOC |
No |
No |
No |
Yes |
STAKE_PROD_LOC |
No |
No |
No |
Yes |
STAKE_PRODUCT |
No |
No |
No |
Yes |
STAKE_HEAD |
Yes |
No |
No |
Yes |
