Close Transactions with no Expected Appointments, Shipments or Receipts (doc_queue_close_job)
Module Name |
doc_queue_close_job |
Description |
Close Transactions with no Expected Appointments, Shipments or Receipts |
Functional Area |
Transfers, Allocation, and RTVs |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from document close queue table based on un-Closed status of POs, Transfers and Allocations. These unique documents that do not have any outstanding appointments, shipments or receipts expected, receipts without appointments will be recorded on the document close queue table. Likewise, allocations sourced from an inbound receipt of another document (for example, POs, Transfers, Allocations, ASNs and BOLs) can only be closed if the sourcing document is closed. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will update the records of each document type to attempt closure of each document. PO-type documents will call APPT_DOC_CLOSE_SQL.CLOSE_PO program. Transfer-type documents will call APPT_DOC_CLOSE_SQL.CLOSE_TSF program. Allocation-type documents will call APPT_DOC_CLOSE_SQL.CLOSE_ALL_ALLOCS program. All successful closure of document will be removed its entry from document close queue table. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 13-2 Key Tables Affected
| Table | Select | Insert | Update | Delete |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
B8D_DOC_CLOSE_QUEUE_STG |
Yes |
Yes |
No |
Yes |
DOC_CLOSE_QUEUE |
Yes |
No |
No |
Yes |
ORDHEAD |
No |
No |
Yes |
No |
DEAL_CALC_QUEUE |
No |
No |
No |
Yes |
ITEM_LOC_SOH |
No |
No |
Yes |
No |
TSFHEAD |
No |
No |
Yes |
No |
ALLOC_HEADER |
No |
No |
Yes |
No |
