End of Year Inventory Position Snapshot (nwpyearend)
Module Name |
nwpyearend.pc |
Description |
End of Year Inventory Position Snapshot |
Functional Area |
Stock Count |
Module Type |
Business Processing |
Module Technology |
ProC |
Catalog ID |
RMS278 |
Wrapper Script |
rmswrap_multi.ksh |
Design Overview
This program takes a snapshot of the item's stock position and cost at the end of the year. When the end of year NWP snapshot process runs, it takes a snapshot of stock and weighted average cost (WAC) for every item/location combination currently holding stock. If there is not a record already on the NWP table for an item/location/year combination in the snapshot, a new record is added for that item/location/year combination.
Restart/Recovery
The logical unit of work for this program is set at the location/item level. Threading is done by supplier using the v_restart_store_wh view to thread properly. The commit_max_ctr field should be set to prevent excessive rollback space usage, and to reduce the overhead of file I/O. The changes will be posted when the commit_max_ctr value is reached and the value of the counter is subject to change based on implementation.
Design Assumptions
NWP refers to 'Niederstwertprinzip' and is a legal German accounting financial inventory reporting requirement for calculating year-end inventory position based on the last receipt cost.
The NWP Indicator system parameter supports this German specific inventory reporting requirement. For German customers, this needs to be 'Y' to allow for the annual NWP calculations & processes.
This is not relevant for customers outside Germany.
