Future Cost Table Maintenance (future_cost_purge_job)
Module Name
Description
Functional Area
Costing
Module Type
Admin - Ad hoc
Module Technology
Background Processing
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Oracle Retail Merchandising Batch Schedule
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from future cost table for purging. These records are chunked, and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete future-cost data from future-cost table. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
This process also supports archiving, if desired. For more information on how to configure this process for archiving, see the Merchandising Implementation Guide section titled "Background Configuration Process".
Restart/Recovery
N/A
Locking Strategy
N/A
Security Considerations
N/A
Performance Considerations
N/A
Key Tables Affected
Table 9-2 Key Tables Affected
Table Select Insert Update Delete
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
SYSTEM_OPTIONS
Yes
No
No
No
PERIOD
Yes
No
No
No
FUTURE_COST
Yes
No
No
Yes
B8D_FUTURE_COST_PURGE_STG
Yes
Yes
No
Yes
JOB_AUDIT_LOGS
No
Yes
No
No
FUTURE_COST_PRG_HIST
No
Yes
No
No
I/O Specification
N/A
