Purge Aged Cost Events (cost_event_purge_job)
Module Name
Description
Functional Area
Future Cost
Module Type
Admin - Ad hoc
Module Technology
Background Processing
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Design Overview
This background job is composed of two-step processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from cost event table based on its purge criteria from system parameter settings. The Cost Events History Days parameter will determine cost events that were old/aged from the creation date. These cost event records should exist from Cost Event Configuration table. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from specific cost event related tables as per Run Event Type. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 9-4 Key Tables Affected
Table Select Insert Update Delete
PURGE_CONFIG_OPTIONS
Yes
No
No
No
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_COST_EVENT_PURGE_STG
Yes
Yes
No
Yes
COST_EVENT
No
No
No
Yes
COST_EVENT_RESULT
No
No
No
Yes
COST_EVENT_THREAD
No
No
No
Yes
COST_EVENT_SUPP_COUNTRY
No
No
No
Yes
COST_EVENT_NIL
No
No
No
Yes
COST_EVENT_PRIM_PACK
No
No
No
Yes
COST_EVENT_COST_CHG
No
No
No
Yes
COST_EVENT_RECLASS
No
No
No
Yes
COST_EVENT_DEAL
No
No
No
Yes
COST_EVENT_MERCH_HIER
No
No
No
Yes
COST_EVENT_ORG_HIER
No
No
No
Yes
COST_EVENT_COST_ZONE
No
No
No
Yes
COST_EVENT_ELC
No
No
No
Yes
COST_EVENT_SUPP_HIER
No
No
No
Yes
COST_EVENT_ITEM_COST_ZONE
No
No
No
Yes
COST_EVENT_RUN_TYPE_CONFIG
Yes
No
No
No
COST_EVENT_DEAL_PASSTHRU
No
No
No
Yes
COST_EVENT_COST RELATIONSHIP
No
No
No
Yes
COST_EVENT_COST_TMPL
No
No
No
Yes
Design Assumptions
N/A
