Purge Aged Customer Orders (customer_orders_purge_job)
Module Name |
customer_orders_purge_job |
Description |
Download Sales and Stock On Hand From RMS to Suppliers |
Functional Area |
Inventory |
Module Type |
Integration |
Module Technology |
ProC |
Catalog ID |
RMS47 |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of one step processing only. It will retain the business logic processing from original KSH script algorithm.
The Business logic program will remove all store fulfillment customer order records from customer order and customer order detail tables based on the purge criteria from the system parameter setting, customer order history months. This will also purge the obsolete records having status 'X' where the customer order could not be created.
