Purge Aged Returns to Vendors (rtv_purge_job)
Module Name |
rtv_purge_job |
Description |
Purge Aged Returns to Vendors |
Functional Area |
Transfers, Allocations and RTVs |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from return-to-vendor header table based on its purge criteria from system parameter settings. The RTV Order History Months parameter will determine the number of months between their completion date and current date exceeds as defined to be outdated records. These old/outdated RTV records should have all debit memos associated to have been posted. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from return-to-vendor header and other related/associated RTV tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 13-4 Key Tables Affected
Table | Select | Insert | Update | Delete |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
B8D_RTV_PURGE_STG |
Yes |
Yes |
No |
Yes |
RTV_HEAD |
No |
No |
No |
Yes |
RTV_DETAIL |
No |
No |
No |
Yes |
INVC_HEAD |
Yes |
No |
No |
Yes |
INVC_DETAIL |
No |
No |
No |
Yes |
INVC_NON_MERCH |
Yes |
No |
No |
Yes |
INVC_MERCH_VAT |
Yes |
No |
No |
Yes |
INVC_DETAIL_VAT |
Yes |
No |
No |
Yes |
INVC_MATCH_QUEUE |
Yes |
No |
No |
Yes |
INVC_DISCOUNT |
Yes |
No |
No |
Yes |
INVC_TOLERANCE |
Yes |
No |
No |
Yes |
ORDLOC_INVC_COST |
Yes |
No |
Yes |
No |
INVC_MATCH_WKSHT |
Yes |
No |
No |
Yes |
INVC_XREF |
Yes |
No |
No |
Yes |
RTVITEM_INV_FLOW |
No |
No |
No |
Yes |
RTV_HEAD_CFA_EXT |
No |
No |
No |
Yes |
