Purge Aged Sales History by Diff (hist_diff_purge_job)
Module Name |
hist_diff_purge_job |
Description |
Purge Aged Sales History by Diff |
Functional Area |
Sales History |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from item-parent-location history by diff and item-location history by diff tables based on its purge criteria from system parameter settings. The Item History Months parameter will determine old sales history differentiator data on a specified system set date. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from sales history differentiator and item-parent-location history tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 15-2 Key Tables Affected
Table | Select | Insert | Update | Delete |
PURGE_CONFIG_OPTIONS |
Yes |
No |
No |
No |
PERIOD |
Yes |
No |
No |
No |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
B8D_HIST_DIFF_PURGE_STG |
Yes |
Yes |
No |
Yes |
ITEM_DIFF_LOC_HIST |
No |
No |
No |
Yes |
ITEM_PARENT_LOC_HIST |
No |
No |
No |
Yes |
