Purge Export Data (export_stg_purge.ksh)
Module Name |
export_stg_purge.ksh |
Description |
Purging of all the extracted records (week old) for Xstore. |
Functional Area |
Foundation |
Module Type |
Integration |
Module Technology |
Ksh |
Catalog ID |
RMS265 |
Wrapper Script |
rmswrap_shell.ksh |
Design Overview
This batch job will be used to remove records that are a week old from the following staging tables.
Merchandise Hierarchy Export Staging
Organizational Hierarchy Export Staging
Store Export Staging
Differentiator Export Staging
Differentiator Group Export Staging
Item Export Staging
VAT Export Staging
Related Item Export Staging
Data Export History
Batch will purge all the records (Week old records) from its respective staging table whether data get extracted or not.
