Purge Job Auditing Logs (job_audit_logs_purge_job)
Module Name |
job_audit_logs_purge_job |
Description |
Purge Old Job Auditing Logs |
Functional Area |
Administration |
Module Type |
Admin - Ad hoc |
Module Technology |
Background processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of one step processing only. This new program/job will use the newly created support program maintain for purging records where affected table is partitioned.
The Business logic program will invoke a call to a new program specific for handling historical logging table that is considered a partitioned table. A package function is called passing the target table name and will execute the proper deletion/purging of records from target table by exercising table partitioning handling such as Dropping Interval Partition (same as truncate or delete from table). There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop job with a flip of this indicator.
The purge program considered the system parameter setting, Job Logging History Months (job_log_hist_months) to determine those records that are older than a predetermined number of months.
