Package Name: RMS_ASYNC_PROCESS_SQL
Spec file name: rmsasyncprocs.pls
Body file name: rmsasyncprocb.pls
Function Level Description – ENQUEUE_STKLGR_INSERT
Function: ENQUEUE_STKLGR_INSERT
(O_error_message IN OUT RTK_ERRORS.RTK_TEXT%TYPE,
I_rms_async_id IN RMS_ASYNC_STATUS.RMS_ASYNC_ID%TYPE)This function adds the RMS_ASYNC_ID associated with the JOB_TYPE STKLGR_INSERT to the asynchronous queue which is created when entering data into theSTOCK_LEDGER_INSERTS table. It also creates entries in the RMS_ASYNC_STATUS and RMS_ASYNC_RETRY tables to track the status of the asynchronous job.
Function Level Description – ENQUEUE_STKLGR_INSERT_RETRY
Function: ENQUEUE_STKLGR_INSERT_RETRY
I_rms_async_id IN RMS_ASYNC_STATUS.RMS_ASYNC_ID%TYPE)This function inserts the RMS_ASYNC_ID associated with a STKLGR_INSERT event into the asynchronous queue again for re-processing. It is invoked through the asynchronous job log form.
Function Level Description – NOTIFY_STKLGR_INSERT
Procedure: NOTIFY_STKLGR_INSERT (context raw,
reginfo sys.aq$_reg_info,
descr sys.aq$_descriptor,
payload raw,
payloadl number)This procedure is called during the de-queue process. This procedure calls the function CORESVC_STKLEDGR_INSERTS_SQL.PROCESS_STKLEDGR_INSERTS for stock ledger and budget table creation. Once the stock ledger and budget table creation is completed successfully it calls the function RMS_ASYNC_PROCESS_SQL.WRITE_SUCCESS to update the status of the RMS_ASYNC_ID as success. If there is a failure in stock ledger and budget table creation, it calls the function RMS_ASYNC_PROCESS_SQL.WRITE_ERROR to update the status to ‘error’ and update the error message. The user is notified about the success/failure of the stock ledger and budget table creation process.
