Supplier Cost Change Extract (sccext)
Module Name |
sccext.pc |
Description |
Apply Pending Cost Changes to Items |
Functional Area |
Cost Change |
Module Type |
Business Processing |
Module Technology |
ProC |
Catalog ID |
RMS355 |
Wrapper Script |
rmswrap_multi.ksh |
Design Overview
The sccext module selects supplier cost change records that are set to go into effect the next day and updates the Merchandising item/supplier/country tables with the new cost. The item/location tables are also updated with the new cost if the cost change impacts the primary supplier/country for an item/location, as this is considered a base cost change. The process also triggers a recalculation of cost and deal application for pending purchase orders.
