Create Stock Count Requests Based on Schedules (stake_sched_explode_job)
                               Module Name  |
                               stake_sched_explode_job  |
                               Description  |
                               Create Stock Count Requests Based on Schedules  |
                               Functional Area  |
                               Stock Counts  |
                               Module Type  |
                               Admin - Ad hoc  |
                               Module Technology  |
                               Background Processing  |
                               Catalog ID  |
                               N/A  |
                               Wrapper Script  |
                               b8dwrap.ksh  |
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from stake count schedule and store or location list tables based on its review criteria from system parameter settings. The Stake Count Review Days parameter will determine and evaluate scheduled counts that are planned for x days from the current day. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will create stock count requests based in the pre-defined schedules for a location. For Unit counts, the item list specified is exploded out to the transaction-level and written to the count/item/location table. For Unit & Value counts, the transaction-level items contained in the specified department/class/subclass will be written to the count/item/location and count/product/location tables. If the schedule was created using a location list, then this process also explodes that down to the store or virtual warehouse level. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 16-1 Key Tables Affected
| Table | Select | Insert | Update | Delete |
                                  RMS_BATCH_STATUS  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  B8D_PROCESS_CONFIG  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  JOB_AUDIT_LOGS  |
                                  No  |
                                  Yes  |
                                  No  |
                                  No  |
                                  B8D_STKSCHED_EXPLODE_STG  |
                                  Yes  |
                                  Yes  |
                                  No  |
                                  Yes  |
                                  STAKE_SCHEDULE  |
                                  Yes  |
                                  No  |
                                  Yes  |
                                  No  |
                                  V_RESTART_STORE_WH  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  PERIOD  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  CODE_DETAIL  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  STAKE_HEAD  |
                                  No  |
                                  Yes  |
                                  No  |
                                  No  |
                                  STAKE_LOCATION  |
                                  No  |
                                  Yes  |
                                  No  |
                                  No  |
                                  STAKE_PRODUCT  |
                                  No  |
                                  Yes  |
                                  No  |
                                  No  |
                                  STAKE_PROD_LOC  |
                                  No  |
                                  Yes  |
                                  No  |
                                  No  |
                                  STAKE_SKU_LOC  |
                                  Yes  |
                                  Yes  |
                                  No  |
                                  No  |
                                  ITEM_MASTER  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  DEPS  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  SUBCLASS  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  PACKITEM  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  ITEM_LOC  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  SKULIST_DETAIL  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  LOC_LIST_DETAIL  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  LOCATION_CLOSED  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  COMPANY_CLOSED  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
                                  INV_TRACK_UNIT_OPTIONS  |
                                  Yes  |
                                  No  |
                                  No  |
                                  No  |
