Purge Aged Transfers (transfer_purge_job)
Module Name |
transfer_purge_job |
Description |
Purge Aged Transfers |
Functional Area |
Transfers, Allocations and RTVs |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from transfer header table and other associated transfer-related tables based on its purge criteria from system parameter settings. The Transfer History Months parameter will determine what transfer records are ready for purging that are considered closed or deleted in status and comparison of transfer close date with tomorrow's current date. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from transfer header and other associated transfer tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 13-5 Key Tables Affected
| Table | Select | Insert | Update | Delete |
PERIOD |
Yes |
No |
No |
No |
SYSTEM_OPTIONS |
Yes |
No |
No |
No |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
B8D_TRANSFER_PURGE_STG |
Yes |
Yes |
No |
Yes |
TSFHEAD |
Yes |
No |
No |
Yes |
TSFDETAIL |
No |
No |
No |
Yes |
ALLOC_HEADER |
Yes |
No |
No |
Yes |
ALLOC_DETAIL |
No |
No |
No |
Yes |
ALLOC_CHRG |
Yes |
No |
No |
Yes |
ALLOC_PURGE_QUEUE |
Yes |
No |
No |
No |
DOC_PURGE_QUEUE |
Yes |
No |
No |
No |
SHIPSKU |
Yes |
No |
No |
Yes |
CARTON |
No |
No |
No |
Yes |
TSFHEAD_CFA_EXT |
No |
No |
No |
Yes |
TSFHEAD_L10N_EXT |
No |
No |
No |
Yes |
TSF_ITEM_COST |
No |
No |
No |
Yes |
TSF_ITEM_WO_COST |
No |
No |
No |
Yes |
TSF_PACKING |
Yes |
No |
No |
Yes |
TSF_PACKING_DETAIL |
No |
No |
No |
Yes |
TSF_XFORM |
Yes |
No |
No |
Yes |
TSF_XFORM_DETAIL |
No |
No |
No |
Yes |
TSF_WO_HEAD |
Yes |
No |
No |
Yes |
TSF_WO_DETAIL |
No |
No |
No |
Yes |
TSFDETAIL_CHRG |
No |
No |
No |
Yes |
ORDCUST |
Yes |
No |
No |
Yes |
ORDCUST_CUSTOMER_DETAIL |
No |
No |
No |
Yes |
ORDCUST_DETAIL |
No |
No |
No |
Yes |
ORDCUST_PUB_INFO |
No |
No |
No |
Yes |
SHIPITEM_INV_FLOW |
No |
No |
No |
Yes |
SHIPSKU_PRG_HIST |
No |
Yes |
No |
No |
ORDCUST_DETAIL_PRG_HIST |
No |
Yes |
No |
No |
ORDCUST_PRG_HIST |
No |
Yes |
No |
No |
TSFDETAIL_CHRG_PRG_HIST |
No |
Yes |
No |
No |
TSF_WO_DETAIL_PRG_HIST |
No |
Yes |
No |
No |
TSF_WO_HEAD_PRG_HIST |
No |
Yes |
No |
No |
TSF_XFORM_DETAIL_PRG_HIST |
No |
Yes |
No |
No |
TSF_XFORM_PRG_HIST |
No |
Yes |
No |
No |
TSF_PACKING_DETAIL_PRG_HIST |
No |
Yes |
No |
No |
TSF_PACKING_PRG_HIST |
No |
Yes |
No |
No |
TSF_ITEM_WO_COST_PRG_HIST |
No |
Yes |
No |
No |
TSF_ITEM_COST_PRG_HIST |
No |
Yes |
No |
No |
TSFDETAIL_PRG_HIST |
No |
Yes |
No |
No |
TSFHEAD_L10N_EXT_PRG_HIST |
No |
Yes |
No |
No |
TSFHEAD_CFA_EXT_PRG_HIST |
No |
Yes |
No |
No |
TSFHEAD_PRG_HIST |
No |
Yes |
No |
No |
