Store Add Asynchronous Process (straddbatch.ksh)
Module Name |
straddbatch.ksh |
Description |
Store Add Asynchronous Process |
Functional Area |
Foundation Data |
Module Type |
Admin |
Module Technology |
.ksh |
Catalog ID |
RMS496 |
Runtime Parameters |
N/A |
Business Overview
This asynchronous process creates new stores in Merchandising, along with all their associated records when a new store is initiated online in Merchandising or via the Store Subscription API.
Key Tables Affected
Table 3-9 Key Tables Affected
Table | Select | Insert | Update | Delete |
STORE _ADD |
Yes |
No |
No |
Yes |
STORE |
Yes |
Yes |
No |
No |
STOCK_LEDGER_INSERTS |
No |
Yes |
No |
No |
RPM_ZONE |
No |
Yes |
No |
No |
RPM_ZONE_LOCATION |
No |
Yes |
No |
No |
RMS_ASYNC_STATUS |
Yes |
Yes |
Yes |
No |
RMS_ASYNC_RETRY |
Yes |
Yes |
Yes |
No |
RMS_ASYNC_JON |
Yes |
No |
No |
No |
LOC_TRAITS_MATRIX |
No |
Yes |
No |
No |
COST_ZONE |
No |
Yes |
No |
No |
COST_ZONE_GROUP_LOC |
No |
Yes |
No |
No |
STORE_HIERARCHY |
No |
Yes |
No |
No |
WF_COST_RELATIONSHIP |
No |
Yes |
No |
No |
SOURCE_DLVRY_SCHED |
No |
Yes |
No |
No |
SOURCE_DLVRY_SCHED_EXC |
No |
Yes |
No |
No |
SOURCE_DLVRY_SCHED_DAYS |
No |
Yes |
No |
No |
COMPANY_CLOSED_EXCEP |
No |
Yes |
No |
No |
LOCATION_CLOSED |
No |
Yes |
No |
No |
POS_STORE |
No |
Yes |
No |
No |
PERIOD |
Yes |
No |
No |
No |
SYSTEM_OPTIONS |
Yes |
No |
No |
No |
STORE_ADD_L10N_EXT |
Yes |
Yes |
No |
Yes |
STORE_ADD_CFA_EXT |
Yes |
Yes |
No |
Yes |
Design Assumptions
The materialized views MV_LOC_SOB, MV_L10N_ENTITY and MV_LOC_PRIM_ADDR will be refreshed after the store has been added. It is assumed that the materialized view will still be available to other processes during the refresh.
Design Overview - Process Steps
This section describes the key design aspect of the store add process.
The overall process consists of 3 steps as outlined below.
New (status-code: 00NEW). This is the status when store is just created.
Store-Add (status-code: 01STOREADD)
Store-Add-Post (status-code: 02STOREADD_POST)
The status-code of the current completed step of the process is updated in store_add.process_status column.
If STORE_ADD.LIKESTORE column is not null for the store, the status will remain in 02STOREADD_POST and the record will be picked up by the likestorebatch.ksh which runs as an hourly job. If not, then the STORE entry will be removed from the STORE_ADD table.
Running entire store-add as batch in case of AQ issues
In case of Oracle AQ issues if store-add step is not running in async mode then entire store-add proess can also be run in batch using below command
storeaddbatch.ksh $UP
This is provided only as a workaround in case of AQ issues. The recommended method is to let store-add step be processed in Async through AQ as it is designed.
Building Schedule Dependencies between Async process and other batches
Customers may need to build scheduling dependencies between async processes and other batch programs. For example, making pos-extract batches dependent upon completion of Like-store step of the store-add process. To do that, create a job in scheduler using following command and make required batches dependent upon this job.
straddasyncwait.ksh $UP "03LIKESTORE"
Similarly, if batch program needs to be made dependent upon other steps, schedule jobs by passing desired status.
Monitoring Progress of Store-Add Processes
The current completed step of the store-add process is updated in store_add.process_status column. In case of a Like-Store step (which is a separate batch program) the status of a store will remain in 02STOREADD_POST, until it is processed by the likestore batch program, which will in turn change the status to 03LIKETORE.
Once the process is completed, the store will be subsequently removed from the STORE_ADD table. If not, then the status will be changed to '05LIKESTORE_FAIL'.
