Stock Ledger Table Maintenance (stock_ledger_purge_job)
Module Name |
stock_ledger_purge_job |
Description |
Stock Ledger Table Maintenance |
Functional Area |
Stock Ledger |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of one step processing only. It will retain the business logic processing from the original batch program algorithm.
The Business logic program will invoke a call to a new program specific for handling historical tables such as Half Data table, and so on. that are considered partitioned tables. PARTITION_SQL.PURGE_INTERVAL_PARTITION is called passing each target table names "HALF_DATA", "DAILY_DATA", "WEEK_DATA", and "MONTH_DATA" This called program will execute the proper deletion/purging of records from target table by exercising table partitioning handling such as Dropping Interval Partition (same as truncate or delete from table).
Key Tables Affected
Table 17-3 Key Tables Affected
| Table | Select | Insert | Update | Delete |
SYSTEM_OPTIONS |
Yes |
No |
No |
No |
SYSTEM_VARIABLES |
Yes |
No |
No |
No |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
ALL_PART_TABLES |
Yes |
No |
No |
No |
ALL_TAB_PARTITIONS |
Yes |
No |
No |
No |
HALF_DATA |
No |
No |
No |
Yes |
DAILY_DATA |
No |
No |
No |
Yes |
WEEK_DATA |
No |
No |
No |
Yes |
MONTH_DATA |
No |
No |
No |
Yes |
