Update ELC Components (batch_compeffupd)
                               Module Name  |
                               batch_compeffupd.ksh  |
                               Description  |
                               Apply Pending Cost Component, Up-charge and ELC Changes  |
                               Functional Area  |
                               Foundation Data  |
                               Module Type  |
                               Business Processing  |
                               Module Technology  |
                               KSH  |
                               Catalog ID  |
                               RMS185  |
                               Wrapper Script  |
                               rmswrap_shell.ksh  |
Design Overview
In Merchandising, users are allowed to make rate changes to cost components, up-charges and expense profiles and assign future effective dates to the changes. Additionally, when these future rate changes are specified, users can choose to cascade these changes to lower levels. The options for how the updates can be cascaded are described in the table below:
Table 3-10 Options for Cascading Updates
| Updated Entity | Cascade Options |
                                  Expense Profiles (Country, Supplier, or Partner)  |
                                  Order, Item  |
                                  Cost Component (Expense)  |
                                  Country, Supplier, Partner, Item, Order  |
                                  Cost Component (Assessment)  |
                                  Item, Order  |
                                  Cost Component (Up-charge)  |
                                  Department, Item, Transfer/Allocation  |
                                  Department Level Up-Charges  |
This batch process is used to process updates to cost components of all types at the expense component level, updates to department level up-charges, and updates to expense profiles at the supplier, country, or partner level. The cascading to other levels is handled in the dependent processes which are run after this process:
Allocation and Transfer Up-charge Update (batch_alloctsfupd)
Expense Profile Update (batch_expprofupd)
Item Cost Component Update (batch_itmcostcompupd)
Purchase Order Cost Component Update (batch_ordcostcompupd)
Department Up-charge (batch_depchrgupd)
