B Appendix - Outbound and Inbound Interfaces
Outbound from WMS Cloud
The following lists all the outbound interfaces from WMS Cloud available in USM, for integration into Merchandising or SIOCS, along with their interface names, template files, service definition files, orchestration files, supported message types, and payloads.
These interfaces have the exact same Failure and Response templates. Namely:
                           LogFireToRib_DefaultAllAction_ResponseDataMapping.template
                           LogFireToRib_DefaultAllAction_FailureResponseDataMapping.template
You will be able to see the details available in these templates in the USM screens to help with resolving any issues in the integration. See also the Integration Errors.
ASN Outbound
This integration will be used for shipments from the warehouse to a store or to another warehouse. It also will be used for customer orders that are shipped to the customer directly.
Inventory Adjustments
Any inventory adjustments that will increment or decrement inventory in the warehouse will be sent via this integration point. This includes removing inventory from stock completely or moving it to and from an available status. See "Appendix - Activity Codes" for more information about mapping inventory adjustments.
Return to Vendor Shipments
This integration will be used when shipping inventory back to a supplier from the warehouse. RTV shipments support returns from both available and unavailable inventory buckets. When shipping out an RTV order from a non-sellable bucket, the inventory disposition codes in the shipment will be based on lock codes in WMS.
Receiving
This integration will be used for receipts of purchase orders, transfers, or allocations into the warehouse. Both container level and detailed receipts will flow through this message to update Merchandising.
Stock Order Status
This integration will be used to communicate updates for stock orders - which can be either a transfer or allocation. Status updates are based on certain activity codes in the Inventory History table in WMS Cloud. See "Appendix - Activity Codes" for more details.
Inbound to WMS Cloud
The following lists the inbound interfaces to interfaces used for integration into WMS Cloud from Merchandising or SIOCS, along with their interface names, template files, service definition files, orchestration files, supported message types, and payload name. Because of how WMS Cloud consumes data, for the following interface points, a full payload is used for sending updates from Merchandising, rather than just the data that changed: items, purchase orders, stock orders, vendors, and RTV requests, using the "FullRep" message type.
The following list of Interfaces have the exact same Failure and Response templates.
                        RibToLogFire_DefaultAllAction_FailureResponseDataMapping.template
                        RibToLogFire_DefaultAllAction_ResponseDataMapping.template
Store
This integration will send new and updated store information from Merchandising to WMS Cloud. If a store is deleted in Merchandising, that will also be communicated to WMS Cloud.
WMS Cloud Integrations
Service Definition
                              RibToLogFireStores_ServiceMappingDef.json
Orchestration File
                              RibToLogFireStores_ServiceMappingOrchestration.smo
Vendor
This integration will send new and updated supplier site information from Merchandising to WMS Cloud. If a supplier site is deleted, that will also be communicated to WMS Cloud.
Service Definition
                              RibToLogFireVendor_ServiceMappingDef.json
Orchestration File
                              RibToLogFireVendor_ServiceMappingOrchestration.smo
External Finisher
This integration will send new and updated external finisher information, including addresses, from Merchandising to WMS Cloud. If an external finisher or its address is deleted, that will also be communicated to WMS Cloud.
Service Definition
                              RibToLogFirePartner_ServiceMappingDef.json
Orchestration File
                              RibToLogFirePartner_ServiceMappingOrchestration.smo
Partner Create (PartnerCre PartnerDtlCre) and Modify (PartnerDtlMod, PartnerMod)
RIB Payload
                              PartnerDesc
Template Files (Request)
                              RibToLogFirePartner_PartnerCre_RequestDataMapping.template
Items
This integration will send new or updated items to WMS Cloud from Merchandising, including parent items, transaction level items, and reference items, as applicable. Only approved items are sent in this integration. For pack items, the component details for the pack are also integrated. See the Items section for key assumptions about items that are integrated to WMS Cloud.
Item Delete is not currently supported in this integration.
Service Definition
                              RibToLogFireItem_ServiceMappingDef.json
Orchestration File
                              RibToLogFireItem_ServiceMappingOrchestration.smo
Item Create (ItemCre, ItemUpcCre, ItemBomCre) and Modify (ItemUpcMod, ItemBomMod, ItemFulRep)
RIB Payload
                              ItemDesc
                              RibToLogFireItem_ItemCre_RequestResponseDataMapping.template
                              RibToLogFireItem_ItemUpcCre_RequestResponseDataMapping.template
                              RibToLogFireItem_ItemBomCre_RequestResponseDataMapping.template
ASN Inbound
This integration is used to map shipments inbound to a warehouse, which could be from a supplier or a store. Modifications to shipments or deletions of a shipment can also occur based on adjustments sent from a store or supplier.
Service Definition
                              RibToLogFireASNIn_ServiceMappingDef.json
Orchestration File
                              RibToLogFireASNIn_ServiceMappingOrchestration.smo
Order
This interface is used to send new and updated purchase orders from Merchandising to WMS Cloud. Only approved orders with a warehouse as one of the destination locations will be sent to WMS Cloud. For more details about PO mapping rules, see the Purchase Orders section.
Service Definition
                              RibToLogFireOrder_ServiceMappingDef.json
Orchestration File
                              RibToLogFireOrder_ServiceMappingOrchestration.smo
Stock Order
Stock orders can be either transfers or allocations, including customer order related transfers. These orders are sent from Merchandising to WMS Cloud when the warehouse is either the shipping location or the receiving location on the stock order. Only approved stock orders will be integrated.
Service Definition
                              RibToLogFireStockOrder_ServiceMappingDef.json
Orchestration File
                              RibToLogFireStockOrder_ServiceMappingOrchestration.smo
RTV Requests
This integration will send return to vendor transactions initiated in Merchandising that are requested to be shipped from a warehouse. Merchandising sends the inventory disposition code in the RTV request if the inventory to be returned is from an unavailable bucket. If the RTV line item is returned from the multiple inventory status codes, then Merchandising sends these codes in a comma-separated list.
Service Definition
                              RibToLogFireRTVReq_ServiceMappingDef.json
Orchestration File
                              RibToLogFireRTVReq_ServiceMappingOrchestration.smo
