7 Download Blank Templates
The Download Blank Template page allows you to download blank templates for certain entities which support spreadsheet upload, such as items and purchase orders.
You can access the Download Blank Template page from the Task menu, select Foundation Data > Data Loading > Download Blank Template. The Download Blank Template page appears.
In the Type field, select the template type from the list.
In the Template field, enter, select or search for the template you want to download.
Then choose one of the following options:
Click Download to download the file. When you click Download, you are prompted to either open or save the .ods file.
Click Revert to undo any changes.
Click Done to close the Download Blank Template Data page.
