4 Item Maintenance
This chapter contains information about the batch processes that relate to item maintenance.
Program Summary
Table 4-1 Item Maintenance - Program Summary
Program | Description |
gtsbuilder |
Global Tax Solution Builder |
item_loc_purge_job |
Daily Purge of Item-Location Data |
itm_indctn_purge.ksh |
Purge Item induction staging tables |
sitmain.pc |
Scheduled Item Maintenance |
vatdlxpl.pc |
Mass VAT Updates for Items/Locations |
Daily Purge of Item-Location Data (item_loc_purge_job)
Module Name |
Description |
Functional Area |
Administration |
Module Type |
Admin - Adhoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
When users 'delete' an item-location record in the Merchandising user interface, information is generally not immediately deleted at the database level; instead, data is marked as being in deleted status and also inserted into the DAILY_PURGE table.
Thread assignment program (ITEM_LOC_PURGE_THREAD) will filter eligible records from daily purge (DAILY_PURGE) table wherein all entities ready for purging are exclusively related to Item-Location (ITEM_LOC table) records. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table B8D_ITEM_LOC_PURGE_STG.
The Business logic program (ITEM_LOC_PURGE) will process all records from the staging table. Using bulk processing, this program will delete item-location data from item-location related and associated tables. Complex referential integrity relationships determine whether data can actually be deleted from the database. This program checks these complex rules. If the deletion request passes the rules, this job will continues to delete the data. If it is not able to delete the data, it writes a record to the DAILY_PURGE_ERROR_LOG table for further investigation. This program will continue to attempt to delete marked data until all references have been purged from the system and the deletion of the item-location data finally succeeds. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 4-2
Table | Select | Insert | Update | Delete |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
B8D_ITEM_LOC_PURGE_STG |
Yes |
No |
No |
No |
DAILY_PURGE |
Yes |
No |
No |
Yes |
DAILY_PURGE_ERROR_LOG |
Yes |
Yes |
No |
Yes |
REPL_RESULTS |
Yes |
No |
No |
Yes |
BUYER_WKSHT_MANUAL |
Yes |
No |
No |
Yes |
SUB_ITEMS_DETAIL |
Yes |
No |
No |
Yes |
SUB_ITEMS_HEAD |
Yes |
No |
No |
Yes |
REPL_ATTR_UPDATE_EXCLUDE |
Yes |
No |
No |
Yes |
MASTER_REPL_ATTR |
Yes |
No |
No |
Yes |
REPL_DAY |
Yes |
No |
No |
Yes |
REPL_ITEM_LOC |
Yes |
No |
No |
Yes |
REPL_ITEM_LOC_UPDATES |
Yes |
Yes |
No |
Yes |
REPL_ITEM_LOC_SUPP_DIST |
Yes |
No |
No |
Yes |
COST_SUSP_SUP_DETAIL_LOC |
Yes |
No |
No |
Yes |
FUTURE_COST |
Yes |
No |
No |
Yes |
ITEM_LOC_MFQUEUE |
Yes |
No |
No |
Yes |
ITEM_LOC |
Yes |
No |
No |
Yes |
ITEM_LOC_SOH |
Yes |
No |
No |
Yes |
ITEM_LOC_TRAITS |
Yes |
No |
No |
Yes |
ITEM_LOC_CFA_EXT |
Yes |
No |
No |
Yes |
ITEM_SUPP_COUNTRY_BRACKET_COST |
Yes |
No |
No |
Yes |
ITEM_SUPP_COUNTRY_LOC_CFA_EXT |
Yes |
No |
No |
Yes |
ITEM_SUPP_COUNTRY_LOC |
Yes |
No |
No |
Yes |
Global Tax Solution Builder (gtsbuilder)
Module Name |
gtsbuilder.ksh |
Description |
GTS Builder Processing |
Functional Area |
Foundation |
Module Type |
Business Processing |
Module Technology |
Ksh |
Catalog ID |
TBD |
Runtime Parameters |
rmswrap_shell.ksh |
Design Overview
This batch program is used to process new, modified or expired rules of the global tax solution. The criteria to find these rules are based on the rule status and the field END_DATE.
Any rule with status UPDATED or APPROVED will be considered to be processed. Rules in status ACTIVE but with the field END_DATE filled with a date older than the tax builder execution date will also be picked for processing.
The processing logic in each of the above scenarios will be:
Processing rules in status UPDATED: rules can be updated exclusively in the field END_DATE. In this case the date informed in the rule will be updated in GTS_MERCHT_TAX and GTS_ITEM_TAX tables. Once these updates are done, the status of the rule will be changed back to ACTIVE.
Processing rules in status APPROVED: rules in this status are basically new rules included in the system. The GTS builder process will also identify rules with conditions at parent level regions or higher level of merchandise hierarchy (dept or class) and will store new records into GTS_MERCH_TAX and GTS_ITEM_TAX table for the lowest level of region (child regions) and merchandise hierarchy (subclass). Once these updates are done, the status of the rule will be changed to ACTIVE.
Processing rules in status ACTIVE: the process will look for the field END_DATE in active rules. If this field is filled with a date older than the execution date, the process will simply change the rule status to CLOSED. No updates will be performed at merchandise level tax tables nor item level tax tables.
Mass VAT Updates for Items/Locations (vatdlxpl)
Module Name |
vatdlxpl.pc |
Description |
Functional Area |
Item Maintenance |
Module Type |
Module Technology |
ProC |
Catalog ID |
RMS384 |
rmswrap_multi.ksh |
Design Overview
This batch program updates VAT information for each item associated with a given VAT region and VAT code.
Purge Item Induction Staging Tables (itm_indctn_purge.ksh)
Module Name |
Description |
Purge item induction staging tables |
Functional Area |
Foundation-Items |
Module Type |
Admin |
Module Technology |
Shell Script |
Catalog ID |
RMS498 |
N/A |
Design Overview
The purpose of this module is to remove old item records from the staging tables. Records that are candidates for deletion are:
Processes that have successfully been processed or processed with warnings that have been uploaded to Merchandising or downloaded to S9T
Processes that have status = 'PE', processed with errors and have no linked data
Processes in error status where all other related records containing the process ID have been processed successfully
Processes that have errors and are past the data retention days (system_options.proc_data_retention_days)
All item records within a process where all related records for the item in the other staging tables are successfully uploaded to Merchandising. The process tracker record for that process should not be deleted if there are other item records that are not uploaded to Merchandising.
Scheduled Item Maintenance (sitmain)
Module Name |
sitmain.pc |
Description |
Functional Area |
Item Maintenance |
Module Type |
Module Technology |
ProC |
Catalog ID |
RMS357 |
Wrapper Script |
rmswrap_multi.ksh |
Design Overview
Scheduled item maintenance is a method of performing mass changes on item/location information. Scheduled item maintenance uses item and location lists to make the process of changing lots of information very easy for end users.This program explodes the intersection of these items and location lists to make the scheduled changes at the specific item/location level.
