7 UI Platform Services
The user interface for the Merchandising solutions has some common components that you may want to use in building custom workflows related to managing user notifications.
These ReST services are packaged as part of the Merchandising solution's Enterprise Archive (EAR) file. Installation of the ReST web services is therefore done by default.
Security
Services are secured using the J2EE-based security model.
  • Realm-based User Authentication: This verifies users through an underlying Realm. The username and password are passed using HTTP basic authentication.
  • Role-based Authorization: This assigns users to roles; authenticated users can access the services within the Merchandising suite.
  • The communication between the server and client is encrypted using one-way SSL. In non-SSL environments the encoding defaults to BASE-64 so it is highly recommended that these ReST services are configured to be used in production environments secured with SSL connections.
Standard Request and Response Headers
The UI platform ReSTful web services have the following standard HTTP headers:
Name Value Required Description
Accept
application/json
OR
application/xml
Optional.
If a response payload is expected instead of just an appropriate HTTP status code
Tells the server the MIME-type of the resource.
Accept-Version
1.8.3
Yes
Depicts which version of the Platform Services is expected.
Accept-Versioning
false
No
Specified in the service request to bypass version validation
Accept-Language
en-US
No
Defaulted by most clients to the destination locale
Content-Type
application/json
OR
application/xml
Optional.
If a request payload is expected. Helps the server determine how to parse the request.
Informs the server during PUT or POST requests, of the format of the payload being sent.
Authorization
Base64 encoded credentials string
Yes
Authenticates a user agent with the server
Depending on the type of the operation or HTTP method, the corresponding response header is updated in the HTTP response with the following codes:
  • GET/READ : 200
  • PUT/CREATE : 201 created
  • POST/UPDATE : 204
  • DELETE : 204
Standard Error Response
Example response payload in case of service error is depicted below:
   <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
   <messagesRDOes>
     <messagesRDO>
        <message>REST Service Version Mismatch</message>
        <messageType>ERROR</messageType>
        <status>BAD_REQUEST</status>
    </messagesRDO>
   </messagesRDOes>
  • Message: The error message - translated.
  • MessageType: Value of 'ERROR' is returned.
  • Status: For a bad request or error, the status is BAD_REQUEST.
  • The http error code for an error response is 400
List of ReST Services
The ReST services exposed by the UI platform are accessible from a URL that is different for each of the Merchandising cloud services. The URLs to use for each solution are:
Merchandising: https://rex.retail.<Region Name>.ocs.oraclecloud.com/<Customer Subnamespace>/RmsPlatformServices/services/private/*
Sales Audit: https://rex.retail.<Region Name>.ocs.oraclecloud.com/<Customer Subnamespace>/ResaPlatformServices/services/private/*
Pricing: https://rex.retail.<Region Name>.ocs.oraclecloud.com/<Customer Subnamespace>/ PricingPlatformServices/services/private/*
Allocation: https://rex.retail.<Region Name>.ocs.oraclecloud.com/<Customer Subnamespace>/AllocPlatformServices/services/private/*
Invoice Matching: https://rex.retail.<Region Name>.ocs.oraclecloud.com/<Customer Subnamespace>/ReimPlatformServices/services/private/*
Notifications
Description URL HTTP Method
Creating Notifications
/Notifications/create
POST
Updating Notifications
/Notifications/update
PUT
Deleting Notifications
/Notifications/delete/{id}
DELETE
Fetch Notifications
/Notifications/fetch?appCode={appCode}
GET
Get number of unread Notifications
/Notifications/fetch/unreadCount?appCode={appCode}
GET
Search Notifications
/Notifications/search?appCode={appCode}
GET
Filter Notifications - Return list of Notifications
/Notifications/filter/list
POST
Filter Notifications - Return grouped list of Notifications
/Notifications/filter/group
POST
Filter Notifications - Return a summarized list of Notifications
/Notifications/filter/summarize
POST
Count Notifications matching the filter
/Notifications/filter/count
POST
Persist the Criteria
/Notifications/criteria
POST
Fetch the Criteria
/Notifications/fetch/criteria?appCode={appCode}
GET
Fetch Recipients
/Notifications/fetch/recipients/{id}
GET
Fetch Notification Context
/Notifications/fetch/context/{id}
GET
Fetch Notification Time Periods
/Notifications/fetch/timeperiods?appCode={appCode}
GET
Fetch Notification Hierarchy Levels
/Notifications/fetch/hierarchylevels?appCode={appCode}
GET
Fetch Notification Types
/Notifications/fetch/notificationtypes?appCode={appCode}
GET
Status update for multiple Notifications
/Notifications/update/multiple/status
PUT
Delete multiple Notifications
/Notifications/delete/multiple
POST
