Creating a District
To create a district, follow the steps below.
- On the Locations Destination landing page, click the Organizational Hierarchy card. Alternatively, from the Home Experience, select Organizational Hierarchy from the Product Map or Suggestions list view. The Organizational Hierarchy page appears.
- When the Organizational Hierarchy page opens, the company will be selected and displayed in the focused card with all chains in the company listed in child cards below. You can drill down to the region under which you wish to add the new district by clicking the chain, then area, and then the region. Alternatively, you can search for the desired region by keying a partial or full region ID or name in the Ask Oracle search bar at the top of the page. The region will become the focused card.
- With the region card as the focused card, choose Create District option from
Overflow Menu. The New District drawer appears.
Figure 3-14 New District Drawer
- At the top of the drawer, the chain, area, and region under which the new district will be added are displayed.
- In the District field, enter a unique number. This field is a required field.
- In the District Name field, enter the name of the district. This field is a required field.
- In the Manager field, enter the name of the manager who is responsible for the district.
- In the Currency field, enter, select, or search for the district's currency code.
- In the Region field, enter, select or search for the region ID that is associated with the district. This field is a required field.
- Then choose one of the following options.
- Click Create to save the district and close the drawer.
- Click Cancel to reject all entries and close the drawer.
