Create Regions
To create a region, follow the steps below.
  1. On the Locations Destination landing page, click the Organizational Hierarchy card. Alternatively, from the Home Experience select Organizational Hierarchy from the Product Map or Suggestions list view. The Organizational Hierarchy page appears.
  2. When the Organizational Hierarchy page opens, the company will be selected and displayed in the focused card with all chains in the company listed in child cards below. Select the chain under which you will create a region, then select the area under which you will create the region, or search for the desired area by keying a partial or full area ID or name in the Ask Oracle search bar at the top of the page. The area will become the focused card.
  3. With the Area card as the focused card, choose the Create Region option from the Overflow Menu. The New Region drawer appears.
    Figure 3-11 New Region Drawer
    New Region Drawer
    1. At the top of the drawer, the hierarchy tree is displayed, showing the hierarchy levels above the region being added as read-only fields.
    2. In the Region field, enter a unique number. This field is a required field.
    3. In the Region Name field, enter the name of the region. This field is a required field.
    4. In the Manager field, enter the name of the manager who is responsible for the region.
    5. In the Currency field, enter, select or search for the region's currency code.
    6. The Translations section is enabled when all required details are entered. Click the Create Translation button to add translations. The New Translation page appears.
      • Add the translation. For more information see the "Translate Data" chapter in the Oracle Retail Merchandising Do the Basics User Guide.
    7. Then choose one of the following options.
      • Click Create to save the region and close the drawer.
      • Click Cancel to reject all entries and close the drawer.
