Editing Districts
To edit a district, follow the steps below.
- On the Locations Destination landing page, click the Organizational Hierarchy card. Alternatively, from the Home Experience select Organizational Hierarchy from the Product Map or Suggestions list view. The Organizational Hierarchy page appears.
- When the Organizational Hierarchy page opens, the company will be selected and displayed in the focused card with all chains in the company listed in child cards below. You can drill down to the district you wish to edit by clicking the chain, then area, then region, and then the district. Alternatively, you can search for the desired region by keying a partial or full region ID or name in the Ask Oracle search bar at the top of the page. The region will become the focused card.
- When the Organizational Hierarchy page opens, the company will be selected and displayed in the focused card with all chains in the company listed in child cards below. Select the chain under whichyou will edit the region; the chain will become the focused card. Then select the area under which you want to edit the region; the list of regions will be displayed below the selected area; select the desired region. Alternatively, search for the desired are by keying a partial or full region ID or name in the Ask Oracle search bar at the top of the page.
- With the desired district as the focused card, choose the Edit District option from
the Overflow menu or simply click on the card title that is a hyperlink. The Edit
District drawer appears.
Figure 3-15 Edit District Drawer
- Select Actions > Edit, or use the Edit icon. The Edit District page appears.
- The drawer title displays the District ID.
- The chain and area are displayed as ready-only fields.
- Edit the region, district name, manager, currency and/or region, if necessary.
- You can create and/or edit translations as necessary. For more information see the "Translate Data" chapter in the Oracle Retail Merchandising Do the Basics User Guide.
- Choose one of the following options:
- Click Update to save your changes and close the drawer.
- Click Cancel to reject all entries and close the drawer.
