Editing Regions
To edit a region, follow the steps below.
- On the Locations Destination landing page, click the Organizational Hierarchy card. Alternatively, from the Home Experience, select Organizational Hierarchy from the Product Map or Suggestions list view. The Organizational Hierarchy page appears.
- When the Organizational Hierarchy page opens, the company will be selected and displayed in the focused card with all chains in the company listed in child cards below. Select the chain under which you will to edit the region; the chain will become the focused card. Then select the area under which you want to edit the region; the list of regions will be displayed below the selected area, select the desired region. Alternatively, search for the desired region by keying a partial or full region ID or name in the Ask Oracle search bar at the top of the page.
- With the desired Area as the focused card and choose Edit Region option from
Overflow menu or simply click on card title which is a hyperlink. The Edit Region
drawer appears.
Figure 3-12 Edit Region Drawer
- The drawer title displays the Region ID.
- The chain is displayed as a ready-only field.
- Edit the area, region name, manager, and/or currency, if necessary.
You can create and/or edit translations as necessary.
For more information see the "Translate Data" chapter in the Oracle Retail Merchandising Do the Basics User Guide.
- Then choose one of the following options.
- Click Update to save your changes and close the drawer.
- Click Cancel to reject all changes and close the drawer.
