Editing Stores
To edit a store, follow the steps below.
- To edit a store, you can initiate the process from the Organizational Hierarchy page or the
Stores and Warehouses page.
- Find the store you wish to edit through the Organizational Hierarchy page:
- On the Locations Destination landing page, click the Organizational Hierarchy card. Alternatively, from the Home Experience, select Organizational Hierarchy from the Product Map or Suggestions list view. The Organizational Hierarchy page appears.
- When the Organizational Hierarchy page opens, the company will be selected and displayed in the focused card with all chains in the company listed in child cards below. You can drill down to the district under which you wish to add the new store by clicking the chain, then area, then region, and then district. The stores under the selected district will display as cards below the focused card; select the desired store. Alternatively, you can search for the desired store by keying a partial or full store ID or name in the Ask Oracle search bar at the top of the page. The store will become the focused card.
- With the store card as the focused card, choose Edit Store option from Action menu. The Store page appears.
- Find the store you wish to edit through the Stores and Warehouses page:
- On the Locations Destination landing page, click the Stores and Warehouses card. Alternatively, from the Home Experience select Stores and Warehouses from the Product Map or Suggestions list view. The Stores and Warehouses page appears.
- Enter keywords or select filters in the Ask Oracle search bar at the top of the page to filter the locations displayed on the page. When you find the store you wish to edit, from the Card View, click the Edit button on the store card, or from the Table View, select Edit from the Action menu on the row. The Store page appears.
- Edit the fields, if necessary. For more information about the available fields in the Store page, see the Store Page section.
