Increasing the Quantity Ordered in Order Maintenance
Purpose: You can use the Work with Order Line Screen to increase the quantity ordered of an item on an existing order.
Retail pickup or delivery orders: You cannot increase the quantity on a retail pickup or delivery order from Order Orchestration. See the Retail Pickup (including Ship-for-Pickup) or Delivery Orders for more information.
For more information:
- decreasing the quantity ordered of an item: Canceling an Item in Order Maintenance
- how price table repricing and premium items function in Order Maintenance: Changing Item Detail Line Information in Order Maintenance
Instructions:
- At the Work with Order Lines Screen, Select Change for an item. You advance to the Work with Order Line Screen with your cursor in the Qty field.
- Enter the amount of the item that the customer wants to order.
- Select OK to accept and validate the new quantity ordered and return to the Work with Order Lines Screen.
- The system updates the quantity ordered immediately. Notice the quantity in the Rsv (reserved) field if you are using Immediate Reservation.
- This option is available only for open or held order lines without a printed quantity.
- When you change the quantity ordered of a main set item, the change is also reflected in its component items.
- Selecting Change for a set component item is controlled by the Set Component Maintenance (J01) secured feature. If you do not have the required authority, the system displays an error message: Not authorized to change, delete, cancel, or sell out a set component.
