Edit Attribute Definition
Purpose: Use the Edit Attribute Definition screen to review or edit an attribute.
Used for the Routing Engine module.
For more information: See Using Attribute Rules for Delivery and Pickup Orders and Using Attribute Rules for Ship-for-Pickup Orders for background.
How to display this screen: Click the edit icon (
) for an
existing attribute at the Attribute Definitions screen.
- Available if Use Routing Engine is selected at the Tenant screen. Only users with Attribute Definitions authority can display this screen. See the Role Wizard for more information.
- If the Edit Attribute Definition screen was already open in another tab when you clicked the edit icon, you advance to this screen with the previous attribute information displayed.
Fields at this screen: Update any of the fields described below and click Save, or click Cancel to return to the Attribute Definitions screen without saving changes to the attribute.
| Field | Description |
| Organization |
See organization. Defaults from the Attribute Definitions screen. Display-only. |
| Attribute Code |
The Code identifying an attribute you can apply to locations, products, or both. Attribute codes can be 1 to 40 positions in length and must be unique within the organization. The code can include special characters, but cannot include any spaces. Display-only. |
| Last Updated |
The most recent date and time when the attribute definition was updated. |
| Description |
The description of the attribute. Can be up to 100 positions. Required. |
| Attribute Type |
Indicates how you can apply the attribute:
| Ship For Pickup Matching Type |
Indicates whether to filter a location based on its role in fulfilling a ship-for-pickup order:
Note: This setting does not control routing of delivery or pickup orders and is used only if ship-for-pickup orders are enabled. |
| Allow Multiple |
Select if multiple values for the attribute can be assigned to the same product or location; otherwise, leave blank. For example, select this flag if locations can support pickup of orders with two different brands; in this case, the attribute is assigned to the location for both brands, with a Location Use of Pickup. Boolean attributes do not support allowing multiples. Also, regardless of this setting, multiple values for the attribute cannot be applied to a location with a Location Use of Originating Location.
| Data Type |
Indicates the type of data that can be defined through the attribute. Defaults from the Attribute Definitions screen. Available data types are:
Required if the attribute has not yet been applied to a location or product; otherwise, display-only if it has been applied. |
| The following fields are included only when the Data Type is List. | |
| Values |
Use this field to enter each supported value that can be applied for a list attribute. For example, if the attribute is for brand, the values might be the name of each supported brand. Each value can be up to 50 positions. At least one value is required. Click Add Value after entering each new value. Duplicates? If you enter the same value more than once, no error is displayed, and the duplicate value is added to the Current Values area; however, when you save the attribute definition, any duplicates are deleted. Remove Value: You can remove a value from the list only if it has not been applied to a product or location. Values are case-sensitive. If you enter ABC and abc, both values are saved. |
| Current Values (unlabeled field between the Add Value and Remove Value option) |
The current existing values for the list. You can delete an existing value by highlighting it and then clicking Remove Value; however, you cannot delete any values that have been applied to a location or product. |
