Edit Location Attribute
Purpose: Use the Edit Location Attribute window to change the value for a location attribute.
Used for the Routing Engine module.
For more information: See Using Attribute Rules for Delivery and Pickup Orders and Using Attribute Rules for Ship-for-Pickup Orders for background.
How to open this window: Click the edit icon (
) at the Location Attributes screen.
Fields at this window:
Boolean location attributes cannot be edited. You can delete a Boolean attribute if it should not apply to the location.| Field | Description |
| Location |
See location. The location you selected at the Locations screen. The location code is separated from the location name by a hyphen (-). Display-only. |
| Location Use |
Indicates whether the attribute applies to the location when it is the Originating, Pickup, or Sourcing location for an order. Display-only. In the case of a ship-for-pickup order, the Ship For Pickup Matching Type selected for the attribute definition must also indicate to use this attribute when filtering locations; for example, the Ship For Pickup Match Type must be set to Sourcing or Both in order to use a location attribute whose Location Use is set to Sourcing to filter orders. However, this restriction does not apply to delivery or pickup orders. |
| Attribute Code |
The Code identifying the attribute applied to a location. Display-only. |
| Description |
The description of the selected attribute. Display-only. |
| Data Type |
Indicates the type of data that can be defined through the selected attribute. Possible data types are:
Display-only. |
| Value |
Use this field to enter or select the value for the location attribute. If the Data Type is:
Required, except that a Boolean defaults to selected and is display-only. |
