11 Systems Menu
Screens indicated with an asterisk (*) are available from the Systems dropdown menu but not from the Systems area of the home screen.- Event Logging
Vendor User Profiles: Used for the Supplier Direct Fulfillment module. Available if Use Vendor Portal is selected at the Tenant screen.
- Vendor User Profile: Available if Use Vendor Portal is selected at the Tenant screen.
- Browse Vendor User Profile: Available if Use Vendor Portal is selected at the Tenant screen.
Store Associate User Profiles: Used for the Store Connect module. Available if Use Store Connect is selected at the Tenant screen.
- Edit Store Associate User Profile: Available if Use Store Connect is selected at the Tenant screen.
- Browse Store Associate User Profile: Available if Use Store Connect is selected at the Tenant screen.
- Proximity Uploads: Available if Use Routing Engine is selected at the Tenant screen.
*Boxes: Used for the Supplier Direct Fulfillment module, Store Connect module, or both. Available if Use Vendor Portal or Use Store Connect is selected at the Tenant screen.
- *Tenant: advance to either the Tenant (retailer information) screen or the Tenant-Admin screen, depending on whether you are an admin user
- *File Storage History
- *About Order Broker
