10 Locations Menu
Preferences: Used for the Routing Engine module. Available if Use Routing Engine is selected at the Tenant screen.
Drop Ship Preferences: Used for the Supplier Direct Fulfillment module. Available if Use Vendor Portal is selected at the Tenant screen.
Store Connect Preferences: Used for the Store Connect module. Available if Use Store Connect is selected at the Tenant screen.
Order Broker Preference Overrides: Used for the Routing Engine module. Available if Use Routing Engine is selected at the Tenant screen.
Edit Order Broker Preference Override: Available if Use Routing Engine is selected at the Tenant screen.
Browse Order Broker Preference Override: Available if Use Routing Engine is selected at the Tenant screen.
Location Attributes: Used for the Routing Engine module.
New Location Attribute: Used for the Routing Engine module.
Edit Location Attribute: Used for the Routing Engine module.
Location Bulk Updates: Used for the Routing Engine module.
Attribute Definitions: Used for the Routing Engine module.
New Attribute Definition: Used for the Routing Engine module.
Edit Attribute Definition: Used for the Routing Engine module.
Browse Attribute Definitions: Used for the Routing Engine module.
Manage Attribute Definition: Used for the Routing Engine module.
Fulfillment Zones: Used for the Routing Engine module. Available if Use Routing Engine is selected at the Tenant screen.
Fulfillment Zone Wizard: Available if Use Routing Engine is selected at the Tenant screen.
Browse Fulfillment Zones: Available if Use Routing Engine is selected at the Tenant screen.
Vendors: Available if Use Vendor Portal is selected at the Tenant screen. Available if Use Vendor Portal is selected at the Tenant screen.
New Vendor: Available if Use Vendor Portal is selected at the Tenant screen.
Edit Vendor: Available if Use Vendor Portal is selected at the Tenant screen.
