2 Resolved Issues
This section contains a list of the customer-reported bugs that were fixed in this release.
Customer Service
| Bug ID | Description | |
31097483 |
Changed the CWEmailOut XML message for a shipment confirmation to include a separate TrackingNumber element for each carton number, if multiple carton numbers use the same tracking number. Also, the carton_number attribute was not previously included in the description of the CWEmailOut message in the online help, so it was added. This attribute was added in version 11.0 of the message. |
31124737 |
Corrected Modern View order entry (CCOE) to disable the tax ID field if you blank out the tax code for the order, indicating that the order is subject to tax. |
31168321 |
Corrected the structure of the CWEmailOut shipment confirmation message to include the tracking number tags under the correct invoice when Consolidated Invoice is not enabled (Consolidated Invoice (B49) is set to N) and there are multiple invoices for the order. |
31408410 |
Corrected updates to the Order Control Summary table for exchanges, shipments, and returns, to be converted to the local currency when multi-currency by offer is in use. The information in the Order Control Summary table is displayed through the Operations Control Summary (FLSH) in Classic View and at the Operations Summary page in Modern View. |
32176888 |
Corrected hold reason code assignment to apply each type of hold reason that the order is eligible for. For example, an order can be eligible for both a header-level hold and a ship-to hold. |
32402404 |
Corrected Classic View order entry (OEOM) to prevent re-adding an accompanying item to the order after it was deleted. |
32728328 |
Corrected order creation through Modern View order entry to prevent an issue in which the order was not submitted to the ORDR_ASYNC job for order and demand updates if the order was placed on QAS or user hold. |
32785657 |
Corrected tickler creation to create a tickler when an order goes on hold in order maintenance. |
32789632 |
Corrected Modern View to prevent an error that was displayed when you entered a misship item. |
32817437 |
Corrected pre-pick generation to generate a new pre-pick if an order line was canceled through the CWCancel request message, but there is still at least one other eligible line on the order. |
32919351 |
Corrected an issue that occurred when you created an order in Modern View and then also updated arrival dates for drop ship items in Modern View; in this case, information about the order lines was not displayed correctly in Classic View order inquiry. |
Customer Engagement Integration
32422130 |
Corrected the RLTSLSF and RLTCSUP periodic functions to no longer send the home store and signup store (based on the Default Location for ORCE Integration (K69) system control value) for a customer when the customer record already has a Relate ID specified. The RLTSLSF and RLTCSUP periodic functions are used when the ORCE Customer Integration (L37) system control value is set to SALES. |
32865049 |
Corrected the SYNCRDB periodic function to no longer send the home store and signup store (based on the Default Location for ORCE Integration (K69) system control value) for a customer when the relate_cust_sync_success tag in the CWOrderIn message is set to Y, even if the customer record does not have a Relate ID specified. The SYNCRDB periodic function is used when the ORCE Customer Integration (L37) system control value is set to INTERACT. |
Fulfillment
31780336 |
Corrected the PURGPCL periodic function to purge unused pick control labels only if they are older than the Unused Pick Control Purge Days (K83) system control value. |
32785654 |
Corrected Carryover Report generation (PCOR) to produce both the PDF and the CSV version of the report. |
33009770 |
Corrected partial backorder processing through the CWPickIn message to automatically cancel the unreserved order lines for a retail pickup, delivery, or special ship-for-pickup order if the Cancel Reason (Pick In) (L86) system control value specifies a cancel reason. |
Imports and Exports
30851894 |
Corrected the OCDSITM periodic function to no longer log errors if the OCDS Item Price URL (M48) system control value is blank; instead, it simply does not send item price import requests. |
32768442 |
Changed Marketing Download to prevent including any orders that were not created correctly through the order API. |
Order Broker Integration
31479785 |
Corrected CWCancel request processing to prevent writing an Order Transaction History message indicating that a brokered backorder line or a line on a store pickup order was canceled; instead, it writes an Order Transaction History message indicating that the cancellation attempt failed, and generates the cancellation request failure email to the customer. |
32718730 |
Updated the web service definition for the Order Broker Discovery web services to the current version. |
32316815 |
Corrected generation of backorder notices (GBOC) to include order lines whose Order Broker requests were canceled (Z), provided the order lines themselves were not canceled. |
32844316 |
Corrected creation of a fulfilling order for the second line on the order if it was originally assigned to a store location for fulfillment and then assigned back to Order Management System after rejection by the store. |
Payment Processing
30952509 |
Changed authorization logic to include expired authorizations when subtracting the amount that was already deposited, based on Authorization History. |
32460815 |
Corrected the Work with External Authorization Service screen (WASV) to require entry of prefix, user, and password only if the External Service flag is selected. |
32764516 |
Corrected online authorization for an order received through the order API when there are two payment methods, with a manual authorization amount for a partial amount on one payment method and an authorization required for the second, catch-all payment method. |
327648470 |
Corrected an issue with the authorization amount that could occur during pick slip generation when one line on an order ships and bills, and another line partially reserves. |
32821772 |
Corrected the capture request message sent to CyberSource for a deposit or an authorization + deposit to not include the sequence and total count if they are both set to 1. |
32851859 |
Corrected PayPal integration to prevent sending a reversal request for an order cancellation unless all order ship-tos were canceled. |
32902528 |
Corrected the status displayed for an expired authorization when the remaining amount to authorize is less than a dollar and the Authorization Number for Authorizations Under $1.00 (I08) system control value is populated. |
32977382 |
Corrected an issue that prevented authorization reversals to PayPal from processing. |
32982509 |
Corrected an issue with the authorization amount that could occur during pick slip generation or drop ship pick slip/purchase order generation when the order includes a ship-alone item, a drop ship item, and a regular item shipping from the warehouse. |
33110999 |
Corrected amount authorized when a pickable item is added to an order that previously included just a brokered item. This issue occurred if the amount to authorize for the added item was less than for the brokered item. |
33116247 |
Corrected an issue with the authorization amount that could occur during drop ship pick slip/purchase order generation when the order included a brokered item and then a drop-ship item was added to the order. |
System Management
18154 |
Removed the CORS_ALLOWED_ORIGINS property from Work with Admin Properties (CPRP), since it is set by Oracle staff and should not be changed. |
32170807 |
Corrected a situation in which process history header records were deleted prematurely. |
32846049 |
Corrected job monitor rules (WJMO) to begin generating alerts at the Alert After Time provided the Sleep Time has also elapsed. Previously, alerts were not generated until the Sleep Time had elapsed twice. Note: The Alert Time and Re-alert After Time would typically be multiples of the Sleep Time. For example, if the Sleep Time is 5 minutes, the Alert Time and Re-alert After Time might be 10 minutes or 15 minutes. |
32919925 |
Increased the size of the job ID field in the Active Procedures table to prevent an issue that prevented Active Procedure records from being created for submitted jobs. |
32930460 |
Corrected an issue that prevented the INVTRAN_IN job from processing updates. |
33214646 |
Corrected an issue that prevented the CWInventoryInquiry request message from generating a valid response. |
33244933 |
Corrected IJCT processing to prevent a situation in which a job that was already running could be started again. |
33250136 |
Corrected an issue that prevented price changes and clearance price updates from processing through the OCDS integration. |
Taxation
33244785 |
Corrected the tax calculation for returns when AvaTax is in use. |
User Interface
17679 |
Corrected multiple user interface issues in Modern View that affected accessibility by removing pagination options from all pages that display lists. Instead of requiring you to advance from page to page to see additional records, the pages now display the full results, which you can scroll through. |
32768507 |
Corrected Work with Outbound Interface Transactions (WOIT) to enable searching for trigger records when there is a large number of records. |
