2 Resolved Issues
This section contains a list of the customer-reported bugs that were fixed in this release.
Customer Service
Affected Component Defect Number Summary
Customer Service
35707569
Corrected the issue where the system performed a duplicate PO check in Classic View Order Entry which resulted in an error message.
Customer Service
35896348
Corrected the issue where the user experiences OMS slowness when searching for an order by an alternate order number in Modern View.
Customer Service
35908631
Corrected an issue so now the Order Inquiry screen displays an Expected Ship Date because the order detail line has been updated to include an expected ship date for an order line that has been brokered.
Customer Service
35957695
Corrected the issue where Warehouse Ranking Logic was failing in Modern View when the order had more than two items and the available inventory in the warehouses was less than 2X of the quantity to be reserved.
Customer Service
35964540
Changed warehouse list logic to work correctly in scenarios where there is more than one item on the order and the available inventory is low.
Customer Service
36025752
Corrected Bill Async to process records based on priority and date of creation.
Customer Service
35957706
Corrected the validation for validating Item Warehouse availability to use data from Reserved Order Lines when using Warehouse Lists.
Imports and Exports
Affected Components Defect Number Summary
Imports/Exports
35968797
Corrected the issue so the Periodic Process 'MKT DOWNLOAD EXTRACT' is capturing the 'DDT_QTY_ORDERED' value after an order has been updated to Shipped.
Imports/Exports
36034539
Corrected the CASHIP process to not pick closed records.
Order Broker
Order Broker
35227052
Corrected the issue that prevented the display of the distances for all the records received by Order Broker when checking availability.
Payment Processing
Payment Processing
35700339
Corrected the issue so that when an authorization is rejected by the Decision Manager in Modern View, the payment method is deleted and the user must add another valid payment method to complete the order creation.
Payment Processing
26495
Enhanced Cybersource security standard: new property CYB_PAY_LINK_SERVICE_KEY_PASSWORD added to populate password for p12 Keys. A server restart will be required when the key file and password are rotated.
Payment Processing
35190451
Corrected an issue with performance for the Work with Batch Tokenization (WBTK) process.
Payment Processing
35190446
Corrected an issue with storing data for the Work with Batch Tokenization (WBTK) process.
Payment Processing
35393567
Corrected the Work with Batch Tokenization (WBTK) process to include data in the CCAuthorizationTransaction table.
System Management
System Management
34910624
Deleted any periodic function that contains FLR0234. This class should not be used externally.
User Interface
User Interface
36034076
Corrected the issue so that when an Accented Character is used in the Sold-To/Ship-To Names, Addresses, Cities, and other fields, OMS will render the Letter with the Accent symbol over it.
Web Services
Web Services
35964459
Corrected the issue where Tracking (invoice_tracking_nbr) was not flowing downstream for CUSTHISTIN requests.
Web Services
35964507
Corrected the issue when the freight on the Order is 0, there are "freight" attributes with value 0. The system now records the value 0 as null so no freight attributes are present in the CWINVOICEOUT message.
Web Services
36067141
Corrected an issue that occurred when the order was created at midnight so that the CWInvoiceOut always includes the ohd_enter_time attribute.
