4 Deprecation Advisory
As part of the continuous delivery model for cloud services,
features and technical components of a solution may be removed or
replaced to enhance the security, performance, and overall quality
of the cloud service. When this occurs, the deprecation of a feature
or component will be announced in advance, allowing customers sufficient
time to anticipate the change and transition to any enhanced replacement
feature/component. After the deprecation is announced, the deprecated
feature or component will remain in the solution until the planned
removal date and will not be enhanced or made compatible with other
new features.
No features are deprecated with this update. For a full, current list of declared deprecated features, see the current Deprecation Advisory at Doc ID: 2666109.1.
