Measure Filter Conditions
You can apply the following conditions to various measures depending on the measure data type:
Numeric Measures: Greater than, Less than, equal to, greater than & equal to, less than & equal to, not equal to, between, not between, top values, bottom values,
Boolean Measures: equal to
Date Measure: Greater than, Less than, equal to, greater than & equal to, less than & equal to, not equal to, between, not between
String Measure: Contains, starts with, ends with, equals to
