Copying and Saving Measure Filters
When workbooks are copied or saved with measure filtering applied, then the following rules apply:
Copying View
If a workbook view is copied, any measure filters are copied as well. This means that the copied view is identical to the original. You can remove the measure filter in the copied view to show all positions.
Closing Workbooks
When the workbook is closed and reopened, it opens in the same state with measure filtering as it was closed in. The applied measure filter is retained and the respective measure displays the measure filter icon.
Saving with Format
A measure filter is saved with formats. You can save the measure filters with these Save Format options:
Only for Me
For my Group
Workspace Template
