Measure Filter Conditions
You can apply the following conditions to various measures depending on the measure data type:
Numeric Measures: Greater than, Less than, equal to, greater than or equal to, less than or equal to, not equal to, between, not between, top values, bottom values,
Boolean Measures: equal to
Date Measure: Greater than, Less than, equal to, greater than or equal to, less than or equal to, not equal to, is between, is not between
String Measure: Contains, begins with, ends with, equal to, not equal to.
