4 Manage Conflict Rules
Conflict Rules refer to the set of validations that need to be performed while processing any price event. To improve the overall process of defining and maintaining the conflict rules, a spreadsheet upload process is present within Merchandising. This enables the user to view the entire set of rules that are present, as well as update the permitted ones (enable/disable the rule). The related template is available as part of the Upload/Download Foundation Data screens.
Perform the following procedure to update one or more conflict rules:
From the Tasks menu in Merchandising, select Foundation Data and then select the Download Foundation Data option.
Select the Template Type Price and Cost and the Template Price Event Conflict Rules.
Use the Download button to get the latest version of the rules in a spreadsheet format and make the necessary changes to the existing data.
Upload the updated version of the spreadsheet using the Upload Foundation Data option present under Foundation Data.
