Actions Menu and Icons
See Action Menu and Icons for common actions that can be performed through the Action menu and the icons. You can also perform the following actions:
Table 2-2 Batch Jobs - Actions Menu/Icons and Description
| Actions Menu/Icons | Description |
Edit and Edit icon |
Select an item in the table, then select Actions > Edit or
the edit icon |
Enable All |
Use the Actions > Enable All or the Enable All button to put the process on hold. |
Disable All |
Use the Actions > Disable All or the Disable All button to skip the process. |
