Environment Statuses
Displays the following for each environment:
Figure 2-15 Environment Status
Status - Icon indicating the current status of the integration with the environment. This will be either success
or error
Environment - Abbreviation of the environment name.
Health Check - Opens the Health Check for the environment.
Link - An icon which indicates if Inter-Schedule Dependencies are enabled or disabled.
Active/Inactive Switch - Turning the switch deactivates the job agent for the environment.
