Execution Engine Configuration
The Execution Engine Configuration window displays configuration of communication between the user interface and the execution engine.
Select the Done button to close the window.
This window displays the following configurations:
Figure 2-18 Execution Engine Configuration Window
Executor Service Polling Interval - Determines the number of seconds between each polling interval for the batch execution process on Process Orchestration and Monitoring.
Monitoring Service Polling Interval - Determines the number of seconds between each polling interval for the monitoring process on Process Orchestration and Monitoring.
Thread Pool Size - Maximum number of concurrent threads permitted for use by the Execution Engine.
