Global Edit
Select the Global Edit button to open the Global Edit screen. This screen sets configurations for all the schedules. Refer to the sections above for explanation of the different configurations.
Figure 2-32 Global Edit Screen
Use the Apply check boxes to activate the fields for the settings to be applied to all schedules. The following settings can be applied to all schedules:
Data Retention Days
Long Run Average Time Multiplier
Business Date
Background Jobs
External Dependencies
InterSchedule Dependencies
External URL
External Status Update Mode
Repave Strategy
Credentials:
Username
Password
