Standalone Scheduler Tasks Administration
In the Scheduler Administration screen, the user selects a schedule tile at the top of the screen and the Standalone tab right below the tile. The Standalone cycle's Scheduler tasks are shown in the tasks table.
Figure 2-41 Standalone Scheduler Tasks Administration
The user can either edit the schedule time for each task in-line, or select a task then click the edit icon to change any of the fields shown in the Edit popup below.
The user can also create and delete Standalone tasks.
The user has the option to enter a blank time as long as a frequency in minutes is entered. This will cause the first occurrence to execute immediately.
The Prevent start during nightly switch prevents the task from running while the Nightly batch is running. However, it won’t stop a run that is in progress when the Nightly process starts.
