3 Noteworthy Resolved Issues
This following table highlights specific key fixes that are included in this release. In some cases, only a percentage of the overall fixed defects are listed.
| Affected Component | Defect Number | Description |
User Interface |
33673858 |
INCORRECT BATCH JOB COMPLETION POPUP. When a job is run manually in POM, the following toast notification is shown: “<job name> run successful”. The message is misleading as it suggested the job has completed when it was only submitted for running. This is corrected in POM 22.1.301.0 to show: “<job name> started successfully”. |
